your not going to stick with the the 3 litre or u got bigger and better things on the cards?
Well i must say the 3L /4wd combo is exceptional and people dont realise how much torquer the 3L twin cam is over say an rb26, i dont think i could ever drive anything but a 3L again it just wouldnt do me justice! :P
https://www.sau.com.au/forums/topic/164464-sold/#findComment-3082423
Well i must say the 3L /4wd combo is exceptional and people dont realise how much torquer the 3L twin cam is over say an rb26, i dont think i could ever drive anything but a 3L again it just wouldnt do me justice! :domokun:
so any hints then as to what your going to be doing?
https://www.sau.com.au/forums/topic/164464-sold/#findComment-3083154
will u seperate intake plenum
Yes for the right price, intake plenum comes with borred out tb, modified coolant hose, modified coolant apparatus, aac valve modified, custom accelerator cable and all bits and pieces needed to bolt it straight on!
https://www.sau.com.au/forums/topic/164464-sold/#findComment-3089426
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
