hey guys i am currently in the process of making a sealed box for my pod and i was just wondering if the size of the enclosure relevant to the size of the pod is at all important? is there a way to calculate it? if the size is important would anybody be able to reccomend the size (in litres plz) that i should make the box for this pod, it is an apexi dual funnel filter (pictured below). Also should the box cover the AFM or not?
any help would be much appreciated
cheers
Edited by killswitch88
https://www.sau.com.au/forums/topic/164523-makin-cai-box/
As far as I am aware the size of the box is irrelevant. For your set-up I would add an extra piece of pipe to locate the pod closer down to the hole in the guard, obviously so the side of the filter is closer not the end :O and run some ducting from the front bar up to the bottom of the hole.
I think box is kind of the wrong terminolgy think of it more as a shield thats stopping the pod sucking in hot engine air. Make up the sheild to protect the filter from the engine bay heat, and remember if your making it from aluminium use some type of heatmat on the inside. There is no need to contain the AFM in the box.
<---P.S. woot 1000th post :P
https://www.sau.com.au/forums/topic/164523-makin-cai-box/#findComment-3049416
<---P.S. woot 1000th post :O
im honoured it was in my topic :P
thanks alot for that. btw the box will be sealed and some ducting/piping run down through the front however i never thought of shifting the position of the pod....
thanks alot mate
https://www.sau.com.au/forums/topic/164523-makin-cai-box/#findComment-3049444
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
