Ah, yes, the dark blue one. Well done :P There were a few nice R32 GTR's last night. Yes, the GG R32 GTR has run 10.9 before - single turbo + power FC.
Edited by NXTIME
I saw a few of you guys out there last night - some really good runs! Funny the amount of Skylines that didn't do any burnouts though :P
Did any of you guys see that Purple VL? OMFG!!!
yeah sorry, no burnout from me i dont see the point with the semis i use anyway
i was out there, was my first time in my car in 2months and first time ever on a track, had fun even though the car was overfueling and misfire int LOL. dam coils!
Edited by dead32
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
