hi all. i know a few SAU members made it to the motrkhana sunday and i was wondering if any of you guys have any pics or vidio footage. even friends of yours. or maybe even a link to somthing. i got 2 vids of average quality but havent put them up anywhere yet.
this even also claimed my gearbox thats why i left early so unfortunatly i didnt get to meet to may people and i have NFI where i finished up.
my thoughts were it was a pretty top day with some top cars and a great location. i do however need to find a way to get heat into my semi slics as they caused me a lot of greif with understeer.
Edited by DJRIFT
https://www.sau.com.au/forums/topic/164916-motorkhana-at-the-airport-sunday/
check this link out its gold http://www.youtube.com/watch?v=vuFYCwz3jrw
now when i first looked at this i was pissed off as this guy was not only comparing his pile of scrap to my 32 (not much better) but the guy actualy didnt know what sort of car it was. quote "skyline R31 gts-t". i mean what kind of inbread f^%ks are there in thas corner of the island. he also states at the end where i finished up. well thats all good but i pulled out with a broken box thus i got slowest time plus 5 secconds anyway for all remaining runs. he also shows a run of him getting completly lost because it doesnt look anything like his sisters hairy back. but anyway i gess its 'do you want to watch someone doing some good skids' or do you want to see somone getting lost. pintara boy you are boring and thats a waste of $75.20
thats my little rant so ill go quietly now.
oh and sorry to any other forum users that are from the NW as im sure it is only this on guy and his mates that have been misslead all there lives.
agreed....he was a dickhead, can't drive for s*&t either!
I only have video's of my my 33 and my mates drift 200sx.
like most people they only record them selves. as did i. your mates drift 200 looks tuff i cant wait to see it on the track. i didnt realy get much of a chance to see you or your mate as we were in different groups.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
