hi all. i know a few SAU members made it to the motrkhana sunday and i was wondering if any of you guys have any pics or vidio footage. even friends of yours. or maybe even a link to somthing. i got 2 vids of average quality but havent put them up anywhere yet.
this even also claimed my gearbox thats why i left early so unfortunatly i didnt get to meet to may people and i have NFI where i finished up.
my thoughts were it was a pretty top day with some top cars and a great location. i do however need to find a way to get heat into my semi slics as they caused me a lot of greif with understeer.
Edited by DJRIFT
https://www.sau.com.au/forums/topic/164916-motorkhana-at-the-airport-sunday/
check this link out its gold http://www.youtube.com/watch?v=vuFYCwz3jrw
now when i first looked at this i was pissed off as this guy was not only comparing his pile of scrap to my 32 (not much better) but the guy actualy didnt know what sort of car it was. quote "skyline R31 gts-t". i mean what kind of inbread f^%ks are there in thas corner of the island. he also states at the end where i finished up. well thats all good but i pulled out with a broken box thus i got slowest time plus 5 secconds anyway for all remaining runs. he also shows a run of him getting completly lost because it doesnt look anything like his sisters hairy back. but anyway i gess its 'do you want to watch someone doing some good skids' or do you want to see somone getting lost. pintara boy you are boring and thats a waste of $75.20
thats my little rant so ill go quietly now.
oh and sorry to any other forum users that are from the NW as im sure it is only this on guy and his mates that have been misslead all there lives.
agreed....he was a dickhead, can't drive for s*&t either!
I only have video's of my my 33 and my mates drift 200sx.
like most people they only record them selves. as did i. your mates drift 200 looks tuff i cant wait to see it on the track. i didnt realy get much of a chance to see you or your mate as we were in different groups.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
