thanks 4admrn
we can help and can sent it to your door :)
im after the following,
the centre airvents for the aircon.
triple guage set
well pretty much the centre dash of the car so the whole lot if someone can help me
just jap dont have anything i have called them
or try nisswreck hes a trader on sau... hes in sa but he'd send da part 2 you
They are good guys! :thumbsup:
Could also try:
Z imports in SA http://www.zimports.com.au/catalog/index.php
D1 Garage in SA http://www.d1garage.com/
JMS in SA http://www.japanesemotorsport.com.au/home/
SA FTW!!! :D
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
