^^ have you had any problems with the police?
none as of yet *touch wood*
as long as it's a good balance between allowing the yellow through and looking dark it's not really noticeable unless someone points it out to you. one of those subtle things that you cant quite put your finger on.
it's easily removed with a solvent - that said, reversing is a bitch with the windows and lights tinted
fingers crossed! It looks very smart tho specialy on a black car, i like it well done.
has anyone got pics of their indicators done in that nightshades stuff? i tried my local repco and auto barn and they only had the spray. does normal (window) tint film work on indicators?
I did the spray on my indicators (yellow) just to see what kinda look it gave, and it was sweet.
Just tape around it and spray away.
Ended up swapping to the nismo smoked indicators... same thing.
  • 1 year later...
I like it ALOT!
I have been thinking about doing this to my 4 door R34. Im still deciding.
1. Laws lol
2. If i ever want it the was it was originally (for resale for eg) can I the SPRAY off?
Any help would be much appreciated :happy:
You can get the stuff off fairly easily, but I would recommend a clear gloss over the top cause it does dry almost matt...
I do need to give them a gloss coat..
The lower black strip was done with vinyl...
and thats using clear light assemblies with coloured glodes, I should take a phot of them light up in day to show you...
Edited by 75coupe
Looks good mate did u do that to the outer of your break light or get in behind it?
Its done on the outer of the lens, I guess I could of done it inside the lens but that would mean breaking apart the assembly which is different to stock ones.. If your using the stock light it will definitely need to be done on the outside of course...
Ohh good! :P
I just did the reverse and indicator light on my four door 34 be cos its seperate to the round break lights i wanted to match it to the car (its black) and give it more of a classic skyline look. I just wanted to make sure it was ok to do it to the outside because of sun exposure and such. Just to clarify have u used anything to protect the spray like a gloss coat?
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
