I might add, the turbo's were only taken off to get at the motor, they were externally inspected but not taken apart. Unbolting them shouldn't do anything.
Is everyone here presuming that they were taken apart?
What I want to know from this is why piston 6 melted and has this happened to anyone else.
Also what else should i be asking AVO to check, so far I want:
-air/fuel ratio checked
-injectors checked
-airflow meters checked
-fuel map checked
-ignition timing checked
-power run(may as well)
$6000 is good value.
My rebuild was $9000 as follows
CP forged pistons
Eagle H Beam rods
Tomei Metal head gasket
Tomei sump and rocker cover baffles
Gates racing Kevlar timing belt
ACL Race series bearings
Nissan Gasket set
Reconditioned head and reset valve clearances
All machining, balancing and blueprinting
Remove and reinstall, strip and reassemble
I personally believe if you are going to keep the car and modify then do the best build you can within you budget.
I will definetely keep the car, its a nice car, it may not be as quick as all these guys getting around in their gtst's running 800 pounds of boost with so many guages in the car people think your driving an airplane.
Quite frankly, and I'm rambling on now but, I like how the guages arent 100% accurate, I like how its only got 17 inch wheels and I like the fact that when you race it against something and it wins, and dont get me wrong, it wins alot, you can say that a gtr will beat [insert car], not a gtr will beat a porsche 911 turbo no worries, dont worry about the 500kw's at the wheels or anything. I'm sure that I will catch the "mod" bug eventually, but at the moment my stock gtr and I are gonna spend some time thrashing some vl turbo's and preludes with big drift wings you can hang powerlines off.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
