im thinking of buying this bov but i need suggestion.
Anyone got the Latest 2007 HKS SSQV Blow off valve? i need opinion on this latest model, can anyone tell me if it any better or worst then the previous one, any suggestion on weather to buy this latest model or previous one.
i was reading about it not to long ago, not sure if this applied to the older HKS ones but this one is RoHS compliant and environment friendly.
does that mean its legal? to have this BOV?
the flavour of the year is duck, so you'll hear a lot quacking this year.
i don't see how it can be enviro friendly, still vents the same air to atmosphere, unless they decided to put in some super filter that catches all the crap etc etc
Any BOV that vents atmo is illegal. Period
my goodness, at the levels of modifications the VAST majority of us have done, a/m BOV's are NOT NEEDED!!!
fark! keep the stock one, it's more than up to the task and BETTER.
my goodness, at the levels of modifications the VAST majority of have done, a/m BOV's are NOT NEEDED!!!
i dunno man i notice a slight better spooling rate having a aftermarket BOV
Edited by anDru
i don't think you did. It may have just made it louder and sounded cooler so you may have assumed that it makes you faster. get urself on the dyno with the stock plumbback then change to ur atmo, and notice the no differnce in power.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
