Items are in good condition, all work with no problems. I am located in Logan City (Queensland) willing to post items at buyers expense. Interested in any parts? Contact me on 0433 63 95 97.
Stock ECU: $70 O.N.O
Stock Exhaust with 3" Tip: $60 O.N.O
Stock Intercooler: $30 O.N.O
Edited by KustomR33
https://www.sau.com.au/forums/topic/165584-r33-stock-parts/
Quite a few PM's. All replied too. Everything is still for sale at the moment. I can get photos of items over the weekend if anyone would like them. Thanks.
https://www.sau.com.au/forums/topic/165584-r33-stock-parts/#findComment-3077342
hey buddy, what diameter is the stock intercooler piping?
I'm not 100% sure but I'll measure it for you if your keen, this is from another member who recently took his stock R33 Intercooler off I'm pretty sure it's right.
225 x 185 x 59 - core size
350 - end tanks included
55 - inlet/outlet size
All PM's have been replied to. Thanks.
https://www.sau.com.au/forums/topic/165584-r33-stock-parts/#findComment-3089887
Back to the top we go :nyaanyaa:
Taking offers on all items!
hi mate, you still have the stock exhaust? i need one for an r33 gtst from cat back on a 4 door, not sure if they will be same but will yours pass EPA? should do anyway i need one soon and can swap for a japanese one that i have 4inch
you can call me to discuss on 0421795757
https://www.sau.com.au/forums/topic/165584-r33-stock-parts/#findComment-3113346
