Put it this way... mine is a waste of money... looks good, but thats about it. It never stands steady to be ready when driving so no point of it. Problem is the ECU continusously readjusts itself all the time and is the reason why the signal is constantly modifed and the lights bounce around so much.
A/F meters are useless when ECU is in closed loop,but the moment you step on it, the meter should give stable reading.Run it on the dyno against a good A/F meter and maybe mark with texta different readings on the gauge itself.Otherwise its too generic with its Lean/stoich/Reach positions.
When cruising ( in closed loop mode) it is meant to cycle from rich to lean. That indicates that your oxy sensor is working properly.
When gunning it ( open loop) it should read rich.
The middle of the gauge is stoic (14.7:1). Only thing is, because nearly all factory oxy sensors are only narrow band, they can't tell the difference between a little lean and mega lean. Wheres proper dyno air/fuel gauges are wide band and measure from 10:1 to about 20:1 or so.
    • What's on the front of their building?
    • Jax Tyres Smithfeild Ive gone there a few time, well for tyres. on my 3rd visit I spoke to the dude and told how i just got slugged for rotors, brakes ect. His reply was golden; have you read whats on the front of the building. Never forgot it.       before picture, good friend got all these goodies installed.  Well time to study, servicing, maintenance all before this weekend driving lesson.
    • Hello, first of, I’ve looked at many threads on this code but none have helped me, if you know one that will help me feel free to post a link.   Now to my problem. Recently I was driving and noticed the check engine light came on. I went home and did the test to see what code it gave. I got the 21 code but everything seems fine with the car, no misfire, idle is good, acceleration is the same as when I bought it. I mean no signs of obvious failure. If no misfire is happening I can rule out the coil packs right? Which is about 98% of posts saying it is. If anyone has had this happen and found the issues let me know please. No other lights are on.   The car WAS due for an oil change. I since then changed it so idk if that triggers code 21. Either way it hasn’t turned off.
    • Your both right, it may hold a bit longer then.  Soon I need to change the synchros, should I fit the billet plate while I'm at it? Or just a waste of money?
    • Some of the east coast US Stagea got together this past weekend at Lime Rock Park in CT for Grid Life Circuit Legends. This is probably my favorite pic of the shoot with @Morgan.Mundahl on IG. Hope we get more stags out next year! i think I spotted 5 other than my own at the event.
