  • Replies 132
Hey wanted to ask,
As they come in serial if we have a serial to usb adapter already will that work? Or do we require to purchase the usb adapter from you?
nearly any usb/serial converter will work, so its likely the one u have will be fine...no special requirements are needed (in fact the ones i have are much simpler than normal ones since you only need to use 3 of the 9 pins).
one with a FTDI chip will work best, but my suggestion would be to try the one you've got, and you can always get one from me later on (subject to availability) if it doesnt work. if i run out of stock, ill track down the cheapest one from elsewhere that will work (theres some on uk ebay, and on a US site)
Does this work on a R33 GTR RB26DETT engine?
and also, does this work on a R34 GTT RB25DET?
(on standard ECUs)
if so, i am interested
yes and yes, ive added u to the list. RB26 even support a lot more sensors than most other motors do, which is a bonus
Hey,
I've got an R32 GTS-T. The build date is 10/1989. I've checked my car and it's got the consult port. However you said "find your 23710-xxxxx part number." What part number are you referring too? Also is this a DIY kit or pre-assembled?
if its got the consult port it's almost certainly ok. just checked, and its 9/89 that was the transition month. i think one ecu model that i think supports consult started 8/89. which means i think all 10/89+ will support it, and only few in 9/89 and 8/89 will. the part number is the number on the ecu. if its too hard to get to (passenger kickpanel), i can always accept return (minus postage costs) within say a week if you find it doesnt work on your car.
i dont think ive heard of a confirmed case where a car came from factory with a consult port, but not an ecu that supports consult, so you should be fine!
its preassembled, plug and play. the only DIY bit is plugging it in and running the software :P
good question...i havent personally tried it...im sure vista will have messed up something to make it not work
so u choose the com1 (or whatever) from dropdown, and then it hangs? does anything else change in between? does the display gauges button's text change to say "Connect on port: COMx..."?
changed u to confirmed
also default cable length will be 200cm (as this will make it easier to route behind dash and come out the glove box and reach passenger seat)
Choose COM3
Text says "Connect on port: COM3"
tick
tock
tick
tock
Give it about 40 seconds (on the shitty work laptop) and it says 'Not Responding...' and the shittiness ensues!
Nice.
u sure com3 is right? also what .net framework version and updates have u got installed? (if you know). got all windows updates applied?
id probably need to get vista installed to work out what the issue is. maybe have a try of all previous versions on the site and see if any work, or see where the others fail at.
parts have been received by the place doing board manufacture/assembly, still looking at either side of the weekend of 12-13 May for when boards are received, then a couple days from then for when first interfaces will be available (need the cable/connector assembled)
Brand new built Vista laptop from 2nd week April - v1.1 .Net framework.
Not really too worried now, gave the cable back to it's owner so I never got to run the diags :rolleyes: anyone on westside of Bris who's willing to let me borrow theirs for an afternoon when I get my XP laptop back I'd be hugely grateful!
just got confirmation the boards are being sent out from manufacturer. so should arrive friday, which will allow assembly to start on weekend. so the expected May 14 (Monday) start date will be when I will start contacting people for payment (subject of course to there being no errors/problems with boards, wont know till i get them and test it out)
number of people confirmed by 9AM on Monday will determine price. if we subsequently go over 20 people (but not before 9am monday), SAU will get $5/interface sold, which somewhat make up for all of those who havent yet donated!
well the interface itself will be compatible, but who knows what software works on vista yet? someones already reported ecutalk doesnt for them, so id say theres a reasonable chance it wont work for anyone on vista.
id imagine "some" consult software may work, which that is, who knows.
so im afraid youll have to decide yourself on that. worse-case scenario that nothing works, i should have a compatible ecutalk version by say, end of july?
also:
Software - will NOT be provided on a cd - can be download from here
note the change there - CD's will not be provided, as this would add a $4 or something to shipping as it would no longer be classed as a "letter" but a "parcel"
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
    • I _think_ that one has a christmas tree or some other retainer spike into a hole in that panel under it. Come in under it with thin scredrivers and just pry it gently up. If you rip the ears off the retainer pin....so what? Just stick it back down after with a bit of race tape and carry on with life.
