  • Replies 135
i want my undies.
Honey, if you go downstairs, open that washing machiene of yours, throw in alll of your smelly undies and the clothes on your floor, hit a couple of buttons chuck in some random powery stuff and wait half an hour, let them dry THERES YOUR UNDIES! :(
lol....men :thumbsup:
I have no undies :P
Was is a select few who got them, or is everyone surposed to get them???
Only the people who can fill them out Col
can u get them in a g-string option as i like the bum floss feel :thumbsup::(:laugh:
If you are over the age of 12 i think these undies will turn into a G wether you like it or not...they are rather small
here i thought i was special!!
(meaning yeah i got em too)
with the amount of ppl who have them we could create a new clan!!!
------------ THEE BLUE UNDIED GANG-----------------
sounded more promising in my mind....then again it is a lil late in the night
lol
I read this topic yesterday and was very sad wen i realised that i havent gotten mine either, AND THEN this morning i check for mail and there it is my pair of blue undies YAAAAAAAAAY!!!!!!!!! Not that they'll fit mind yous.
hehehe found mine last night sitting on my desk >_< not much baggage room, but ill struggle by..
nah im just on the 3rd party fire and theft - and covers the full value of my car, i paid $320 which i thought was pretty good. how much have u guys paid for full comp etc??
