also the figures different dynos give can be different.
your guys dyno could be reading high thats why alot of the guys who came to the vic sdu dyno day said thier cars were making 180-190 rwkw on this dyno then they come to our dyno day and only make 140-150.
if the sydney guys have a dyno day then you can compare.
also the air /fuel ratios are important.
ask yourmechanic if he has a reading.
meggala
Guest INASNT
any dyno operator can have your reading 500kw@wheels if they wanted to! i think when u got your car dynoed the first time they bull****ted u man!!
especially with stock comp and rich a/f ratios its impossible!
A guy with a r33 brought his dyno chart to the last melbourne dyno day, after he got his unichip done saying 194kw@wheels. but when he got it dynoed at the day he got 155kw@wheels!
:uh-huh:
Guest INASNT
Originally posted by turbomad
Yes my so called Unichip tune wasn't actually that in tune was it, however he will be fixing it this Sat, and if he can't for some reason then I'll get my money back. So I might be back to check up on his work.
what did the guy have to say when u showed him the graph from the SAU dyno day? did u ask him where your extra 40rwkw's had gone?
As I don't live in Melb I haven't shown him yet, he assured me that there's no way he would have left the A/F ratio at 10:1, so believe me come Sat I'll be sticking around watching his every move making sure he gets it right this time.
Guest INASNT
y dont u get a s-afc or power fc instead of the unichip?
S-AFC - Only intercepts & allows fuel map changes, it doesn't do timing as per the PFC or UC.
Power FC - Costly even @ $1200 for the Power FC add ~$400 for tuning, compare this to a Unichip $1100 fitted & tuned (this is what I paid). Without a doubt the PFC is the better option as reflected by the higher price.
Unichip - IF, & it's a big IF! The UC is correctly installed & tuned then it WILL provide repeatable rwkw gains. My Unichip was able to provide tuning for over 215rwkw (this kind of figure was repeatable on more than one dyno) I also managed the 1/4 time in my sig' with the UC running the show. The power curve & A/FR's were both very smooth & consistent.
BUT...... It took a good tuner who was familiar with both the UC & the RB25DET to get the results! The original installer did a very poor effort @ tuning it. Even the best ECU isn't much good if it's poorly tuned.
Once you start aiming for over 220rwkw the UC "may" have trouble overcoming the stock ECU's AFM over voltage timing retard. This is the exact reason I decided to get the LT12 Microtech, however it "may" be possible to make 220+rwkw with the UC & get a decent power curve, I just wasn’t interested in stuffing around trying to find out!
I think people shouldn't take their dyno reading to personally. A dyno is to tune the car. I've seen some cars sive different reading on the same dyno's.
My one had about 160kw at the rear at Hills and 180kw on 4 wheels on croydon's dyno. :confused:
Yes as Whatisname said it all comes down to cost, I paid $500 for the Unichip and $300 for the so called tune! Now with the SAFC I'd still have to add an ITC to get the same tuning features as the Unichip, which would throw it way over the $800 mark. Now that I've got the Unichip I'll try and get it right, if I can't then sure I'd consider an SAFC, time will tell.
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
