also the figures different dynos give can be different.
your guys dyno could be reading high thats why alot of the guys who came to the vic sdu dyno day said thier cars were making 180-190 rwkw on this dyno then they come to our dyno day and only make 140-150.
if the sydney guys have a dyno day then you can compare.
also the air /fuel ratios are important.
ask yourmechanic if he has a reading.
meggala
Guest INASNT
any dyno operator can have your reading 500kw@wheels if they wanted to! i think when u got your car dynoed the first time they bull****ted u man!!
especially with stock comp and rich a/f ratios its impossible!
A guy with a r33 brought his dyno chart to the last melbourne dyno day, after he got his unichip done saying 194kw@wheels. but when he got it dynoed at the day he got 155kw@wheels!
:uh-huh:
Guest INASNT
Originally posted by turbomad
Yes my so called Unichip tune wasn't actually that in tune was it, however he will be fixing it this Sat, and if he can't for some reason then I'll get my money back. So I might be back to check up on his work.
what did the guy have to say when u showed him the graph from the SAU dyno day? did u ask him where your extra 40rwkw's had gone?
As I don't live in Melb I haven't shown him yet, he assured me that there's no way he would have left the A/F ratio at 10:1, so believe me come Sat I'll be sticking around watching his every move making sure he gets it right this time.
Guest INASNT
y dont u get a s-afc or power fc instead of the unichip?
S-AFC - Only intercepts & allows fuel map changes, it doesn't do timing as per the PFC or UC.
Power FC - Costly even @ $1200 for the Power FC add ~$400 for tuning, compare this to a Unichip $1100 fitted & tuned (this is what I paid). Without a doubt the PFC is the better option as reflected by the higher price.
Unichip - IF, & it's a big IF! The UC is correctly installed & tuned then it WILL provide repeatable rwkw gains. My Unichip was able to provide tuning for over 215rwkw (this kind of figure was repeatable on more than one dyno) I also managed the 1/4 time in my sig' with the UC running the show. The power curve & A/FR's were both very smooth & consistent.
BUT...... It took a good tuner who was familiar with both the UC & the RB25DET to get the results! The original installer did a very poor effort @ tuning it. Even the best ECU isn't much good if it's poorly tuned.
Once you start aiming for over 220rwkw the UC "may" have trouble overcoming the stock ECU's AFM over voltage timing retard. This is the exact reason I decided to get the LT12 Microtech, however it "may" be possible to make 220+rwkw with the UC & get a decent power curve, I just wasn’t interested in stuffing around trying to find out!
I think people shouldn't take their dyno reading to personally. A dyno is to tune the car. I've seen some cars sive different reading on the same dyno's.
My one had about 160kw at the rear at Hills and 180kw on 4 wheels on croydon's dyno. :confused:
Yes as Whatisname said it all comes down to cost, I paid $500 for the Unichip and $300 for the so called tune! Now with the SAFC I'd still have to add an ITC to get the same tuning features as the Unichip, which would throw it way over the $800 mark. Now that I've got the Unichip I'll try and get it right, if I can't then sure I'd consider an SAFC, time will tell.
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
