Thought I may as well throw this up to try spark some interest... :O
Aside from the stupid event name (why do they persist lol), here's hoping this turns out to be a good day of Sport Compact Drag Racing with all the other usual shenanigans that go along with the Ray Box events.
Toyo Tyres Compak Attak - WSID - Saturday 19th May 2007
Event Program
7.00 am Competitor Gates Open
7.00am - 9.30am Show-N-Shine Registration
7.00am - 1.30pm Drag Racing Registration
9.00am Spectator Gates Open
10.00am - 12.45pm Qualifying - SF, SR, SA, SB
10.00am - 3.00pm Show-N-Shine & Club Displays
10.30am Compak Attak Babe Comp
12.15pm Compak Attak Bikini Comp
1.00pm - 5.30pm Qualifying - AM, FM, ST, SM, EX & ET
1.30pm PC, PT & OSB Qualifying Session 1
3.00pm Show-N-Shine Presentation
3.00pm PC, PT & OSB Qualifying Session 2
4.30pm PC, PT & OSB Qualifying Session 3
5.30pm End of Qualifying
6.00pm Drag Racing Eliminations Begin
10.00pm Drag Racing Presentation
PRE-ENTRIES CLOSE MAY 13TH.
DRAG RACING
Cars
Option 1 - Street Entry - $80
(Inc Driver and buddy pass for both days, one car pass & ANDRA Personal Accident cover)
Option 2 - Competition Entry - $130
(Open to ANDRA licence holders only) (Inc Driver and 3 crew passes, 2 car passes & ANDRA Personal Accident Cover)
PRIZE MONEY (only included relevant classes - obviously there are others :sick: )
Class Winner Runner Up
Street RWD $400.00 $200.00
Street AWD $400.00 $200.00
Link for more info
I'm thinking about entering for a bit of fun - $80/$130 isn't too bad really, especially considering it's DYO racing and you could always get lucky and pocket some cash >_<
Who else is going? Is anyone keen?
  • Replies 118
I faxed off my entry form today and looking on the sport compact website.
already entered is
ET Michael Ryan NSW Ford EB Falcon
SR Shane Crichton NSW Toyota Cressida
SR Lee Docherty NSW Mazda MX5
SA Joe Dib NSW Mitsubishi EVO 9
SA Theo Woollett QLD Nissan Skyline R32 GT-R
ST Rodney Spannenberg NSW Mazda RX7
From what I've seen previously, you'd have to expect to get at least 3 qualifying runs, plus your elimination run (assuming you qualify), although these Ray Box events seem to run a little different than the traditional Andra events we're used to having.
Qualifying for Sport RWD, AWD, FWD and Sport Bikes is a single session which runs from 10am - 12.45pm (as opposed to the qualifying rounds for each bracket). Given that the session runs for nearly 3 hours, I think it would be safe to say there'd be ample time for a lot more than 3 runs.
To give some idea, apparently quite a lot of guys did 5 - 6 qualifying runs at Mini Jam earlier in the year, and at a guess, I'd say they would have had more competitors there than what will rock up at WSID, so hypothetically you'd have to expect at least the same amount of runs this time round (i.e 5-6, plus eliminations for those that qualify). Not too bad really...
Perhaps someone in the know can clarify? >_<
You get 3 qualifyers, then if there is time you can line back up and have more "practice runs" which do not count towards anything. The reason they let you do this is because generally there are not many people in the staging lanes and it keeps the spectators seeing cars go down the track.
You should be able to get in at least 4 runs plus the eliminations depending on oil downs etc.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
