ok guys its my moment of truth! REGENCY tomorrow morning!! everything i know of is out and ready so fingers crossed!! theres a few questions i need to answer.. 1- how long is an average inspection? 2- do they check under the dash? 3- wats the deal with exhaust smoke (as mine is blowing a little black due to no tune and sitting around for 6months)? 4- and i dunno about the db of my exhaust....
anyways this is my first trip any tips???
cheers guys if she comes good i will cruise with u guys soon and introduce myself!!!
Edited by rad33
https://www.sau.com.au/forums/topic/166195-defect-cleared/
yes they probably will check everywhere and anywhere, including pilling off the ecu kick plate to see if its aftermarket.
Dont expect to come through first time and u will be ok. U will be suprised what they are most likely to pick on. Inspection tends to take as long as they feel like being picky.
https://www.sau.com.au/forums/topic/166195-defect-cleared/#findComment-3077390
sounds hard
https://www.sau.com.au/forums/topic/166195-defect-cleared/#findComment-3077616
They generally don't check for aftermarket ecu's unless its been defected for it or something doesn't look right. i.e different injectors, afm etc.
Regarding turbo timers etc.. Just make sure its disabled and if possible shove it right up behind the dash where it can't be seen or felt. Good luck getting it back out though as there's next to no room up behind the dash's of these cars. :thumbsup:
https://www.sau.com.au/forums/topic/166195-defect-cleared/#findComment-3078341
ok heres the verdict.....
FAILED lol..
as i expected, but all wasnt bad!! the inspector was a champ! we like talked about new mods and upgrades and wats a good turbo and stuff! he also showed me and gave me tips on getting it back on the road!
ne ways heres the list
-eye level rear brake light
-fuel regulator to be removed (didnt know i had one lol)
-boost controller solenoid to be removed
-rear centre seat belt to be fitted as compliance plate says 5 seater
-oil leak NEAR turbo to be cleaned
-both rack boots broken to be replaced
-RH rear steer inner rack end has play
-fix play at left front wheel bearing
-fix play at left front upper arm
-rh front upper arm bushes have play
-side indicator globes worn, need to be amber
now all i need is help on parts to fix, were i can get them, whos best to do it and $$$$$
oh he didnt even check to sound on my exhaust and he passed my gtr cooler!!
and he never saw my timer!!
https://www.sau.com.au/forums/topic/166195-defect-cleared/#findComment-3079998
sounds like a front left wheel bearing, a couple of bushes and a lil bit of other stuff to do
for the rack boots etc try
Driveshaft & CV Centre
12 Deloraine Rd Edwardstown 5039
(08) 8374 2944
if ya south(ish), i can put ya onto a mobile mechanic who mite be able to do some of that work for ya
otherwise i reccomend
Rod Webb Auto Electrical
2 Muriel Ave Somerton Park 5044
(08) 8294 4599
and of course, Boostworx
https://www.sau.com.au/forums/topic/166195-defect-cleared/#findComment-3080094
FAILED lol..
just make sure you fix those problems for the next inspection and you're bound to pass. Seems like the majority of the problems listed you can do yourself, if you're willing haha.
https://www.sau.com.au/forums/topic/166195-defect-cleared/#findComment-3080575
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
