i know what website ure talking about coz adrian and i saw an item online for a certain price and after goin down to the shop itself it was a couple of hundred dearer. but i have paid cash (no receipt) and ended up saving close to 100 bucks for not paying GST. PM me for name of shop
https://www.sau.com.au/forums/topic/16630-check-carefully/#findComment-342820
As per above, they have to include GST, even if a wholesaler.
If you don't like the place, dob them into ACCC, they'll get done for that.
I hate the old "we didn't include GST since we thought you'd pay cash" - with my company car i can't claim unless i have a full tax invoice - I'l had a few "disagreements" over this, most recently with a $500 purchse.
https://www.sau.com.au/forums/topic/16630-check-carefully/#findComment-343079
Duncan, it's illegal to advertise a price ex GST without stating "plus GST" . It is tax evasion to offer a cash price which doesn't include GST. So if they say "we didn't include GST since we thought you'd paty cash" they are guilty of BOTH tax evasion and false advertising. If they piss you off dob them in to ACCC AND ATO!
https://www.sau.com.au/forums/topic/16630-check-carefully/#findComment-344182
Yeh, I spoke to both our CFO And GM regarding legality and they both visited the web page and came to the conclusion that it was in breach of both ATO and Trade Practices act laws.
I know the shop involved has staff that visit this site they might wish to inform their boss, wouldn't want them to get busted even if it really pissed me off.
https://www.sau.com.au/forums/topic/16630-check-carefully/#findComment-344304
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
