Sad to say but my mate bought an R32 yesterday and being of the younger kind he got cocky and tailwhipped into a tree which spun him into a fone box, im thinking its a rite off, just really sad it was THE FIRST Frikn day. So just be careful in the wet guys, coz seeing injured skylines isnt a pretty thing, lol. Laterssss
Ohh and btw wats a good FMI to get and where to get it fitted, any help is appreciated ive got just over a g atm. cheers
https://www.sau.com.au/forums/topic/166403-farewell-a-fellow-32/
WA= Imports101.
Eastern States= Just Jap
nup it was his first nite out, fu#n idiot, ah well wot u gonna do. think he was gettin insurance monday. :D
Ouch!
As you probably know, getting insurance is as simple as a 20 minute phone call, i bet he's regreting putting that call off til Monday!
Bugger.. especially when its so easy to ring an insurance company and get a cover note that covers the car instantly.
If it is a written off he will no doubt be selling parts off it. I'm after a few interior bits, drop me a pm and I'll forward my number or vice versa.
Wow that sucks but sorry to say, stupidity paid a big part here, he just has to learn a lesson from it; albeit an expensive one!
Hope he's alright however, I know what it feels like to lose a car, happened to my first R33 when someone cleaned me up on the way to work :D
did he crash it like... 3 hours after he bought it. a younger mate of mine mentioned to me a mate of his bought his r32 yesterday or something and smashed it wihtin 3 hours i believe its the same guy haha. f**ken adel, small world.
Yes it was. Friend is a member of R31 club... and he mentioned it on there.....
Wonder if he's liable for the phone box? Police involved at all?
nar think he drove the car off so cops didnt get there fast enough, but yeh went around and had a look at the dmg its not written off but hes bought the parts to fix it and in total costs about $2500-3000 so he must be peaking, ah well, yeh he had the car for about 5 hours i think. :domokun:
Yeah haha thats the guy, my mate mat was around his place with him before today i think or yesterday... had parts for it around the place and he was trying to get it all fixed and was asking me a few questions thru mat about headlights and purge tanks...
Man whenever I buy a car I take it really easy until you know the limits. I don't think I took it for a proper thrash in the hills for about a month after I bought it.
Guess he will learn big time from that mistake.
The thing is these cars have a higher limit than almost all the drivers on here have ability.
Not good At all. This is the reason why I wont drive my car till its insured.
even though this is slighty off topic. anyone know of some nice big roads without many cops, for newbies to take out something with some power, to not end up like this driver?
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
