  • Replies 135
bank details wont work bud, please pm me working bank details... need it without the fulls stop
Hi there,
Just replace the full stop with a space
Regards,
Sherwin
apoligies for the miscommunication mate, all good :)
Not a problem..
Will post off your package ASAP..
You should expect to see it Wednesday or Thursday..
Regards,
Sherwin
is it too late for an R 33 bar.
Hi there,
No it's not too late...
Actually it was perfect timing to ask as more R33 type Lockbars arrived today :)
Regards,
Sherwin
hey im interested in getting one for a r32... do they come with the plugs to block off the lines?? or just the bar?
thanks
Simon
Hi Simon,
It's Just the bar itself, all you will need to purchase is approx. 30cm of Hydraulic Hose and 2 hose clamps to loop the line at the rear :whistling:
Regards,
Sherwin
im also interseted in one for a R32 4 door.
Koree
Hi Koree,
You have been added to the list and Payment details have been sent..
Regards,
Sherwin
Hello everyone,
Just to update those who are interested..
I currently have,
* 16 x Type A Hicas Lockbars
* 23 x Type B Hicas Lockbars
All Ready to be shipped / picked up..
Regards,
Sherwin
I'd probably remove the whole system by looping up near the battery and save about 15kg ;) I removed it all this weekend and installed your bar. You can find further information on the process (with pics)..
here: http://www.nissansilvia.com/forums/locking...13-t185697.html
and here: http://www.skylinesaustralia.com/forums/in...showtopic=93183
I'd probably remove the whole system by looping up near the battery and save about 15kg :D I removed it all this weekend and installed your bar. You can find further information on the process (with pics)..
Hi Gordon,
Thanks for the feedback and the links..
I'm sure i'm not alone when I say it's greatly appreciated :D
Regards,
Sheriwn
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
