hey how far into the western suburbs are you? i live on the gold coast but work in the city....have a gf in coorparoo as well...help a brother out?? :blink:
  • Replies 135
Hi mate,
I am located in the Springfield / Goodna Area.
Regards,
Sherwin
but you come into the city every other day right?
haha ok maybe it's just easier to pay for delivery :rofl:
I've sent you a PM.. I'm sure you will like the solution :blink:
Regards,
Sherwin
you drive a hard bargain....but ok, a blowjob in place of delivery then!
nah that's fair enough, pm replied!
Edited by made_guy
I knew you would like the solution.. :D
PM sent
All PMs replied to.. The list will be updated regularly :D
All Lockbars are still IN stock ready to be shipped..
Regards,
Sherwin
32 gtst still available? will be able to Xfer funds early next week.
Hi there,
Both types are still available :nyaanyaa:
I have sent you a PM with the details..
Regards,
Sherwin
Hi All,
Just to update that there are still Lockbars available in BOTH types :whistling:
I have had a few enquiries for Hydraulic Blocking kits, which would be needed by the A31/S13/R32 Lockbar users, and am looking into offering this aswell :)
I will update the thread with pricing, etc when I have all the information sorted.
And yes they will be available seperately for those who only need the Hydraulic Blocking Kit.
Regards,
Sherwin
Hi there,
That's right mate, you got it in one! :D
These bars replace the rear Hicas Powersteering Pump :)
I have sent you a PM with payment details.
Regards,
Sherwin
Just double checking, this bar fits where the hicas used to. It replaces the hicas if you disconnect and remove, yeh? If so, how do I pay!
hey mate, payment made yesterday for a series 2 R33 Hicas lock bar.
cheers
jaron
Hi Jaron,
You Lockbar has been posted, you should recieve it shortly :)
Just installed mine - went in without a hitch
Thanks Sherwin
Hi Mike,
Glad to hear you like the product :)
Like I said in the first post "Guaranteed Fitment and Strength"
Oh and a update for those interested in the Hydraulic Blocking kits which are required by the Type A Hicas Lockbar users, I should be finalising them on Friday, Hopefully....
So keep an eye on this thread if you are interested in a pack :D
Oh and those who have purchased Lockbars from me, it would be greatly appreciated if you could leave some trader feedback :yes: I have already left feedback for all those who have purchased one :thumbsup:
Regards,
Sherwin
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
