yo dude stencil ur licence plate number on there then there wont be any plates haha
Had thought of using my license plate, but as my mate had pointed out , Whats the point when the plate is 6" above it anyway? ha ha i cant not run a plate for fear of wrong attention.
if i can find my stecil ill bring it to the next autotest for ya mate
Cheers, but ill need it before that. Hoping to have the cooler on by weekend. Planning on making my own if i can be bothered now lol
standard s1 with the number plate area and below removed
So therea a very good chance that with my plate on, the logo will not be visible anyway?
Hopefully putting bumper back on tomorrow night. will know then i guess.
Hi!
Does anyone know whether a Greddy Spec-M Intercooler is any good or should I also go with a Hybrid, as I have seen these around on eBay etc. and was thinking of getting one for my R33 RB25DET?
http://www.modyourcar.com.au/product_info....roducts_id=5101
Thanks!
Pete
Edited by Peter
Hi!
Thanks!
Pete
You trying to take over my thread???? lol
For that question it might be better to start a seperate thread, that way people who have a Greddy cooler will see it, and they can post thier thoguhts. All i can tell you is i have just finished fitting my Hybrid cooler and it seemed pretty easy to fit, and it seems to work well.
Cheers
Brad
Cheers
Brad
easy to fit Brad? not from what i heard and saw lol. at least you finally got it on
Its a bit harder to fit than expected. Still just trying to trim the bumper up neatly. Hopefully should drive out of here tonight. I have bought the heavy duty tools in now
warned you youd need to go hacking the bumper i know it sounds ruff but a grinder really works well if its a plastic bumper the diamond disc just glides thru and you can be reasonably neat to
yea will go thru the bits off the skyline pile and see if i can track that stencil down for ya mate
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
