Arhhh looks like someones playing catchup :D
You have basiclly what I have now Noel, time to choose those cams so I can learn from your R&D... :D
Cause he is staying true to the cause :)
Cam selection has already been made Col. If I told you the specs I would have to kill you tho.
As for the 25 bottom end, well you are partly right. The near stock 25 I currently have impresses the sox off me given its cubic capacity. Just wanna see if i can get the right setup with the new engine to give me the punch I am looking for. If not. Onyabike 25 and welcome aboard 3.o litre.
Supporting mod selection such as cams, manifolds turbo, exhaust etc will be the key to putting the power where I want it. ( and that isnt where you have it) Time will tell if i am right or not.
  • Replies 185
Posted Images
So we have ported head, Hey noel would you please enlist and inform of the mods done to the head, ie valve springs used oversized valves? also Im interested i want to seem that damn flow sheet for the head post that biatch up. Got to know, have you yet sorted your traction and gb issues also clutch.
IE: Stronger clutch in need you going to ring Jim Berry? Or go a strong twin or triple plate clutch.
Gear Box: You going the giken internals or something stronger Getrag? That would help, You can always go the powerglide ;) if your strictly drag specing your car as that is the avenue you looking at taking?
Suspension: Please let me know what you going to choose here. CoilOvers, Whiteline kit?
Brakes: The fundamentals of stopping at the end of the track? Slotted, Upgraded calipers, Grex, Brembo etc. ?
DIFF: I dare say that A-lsd i dont think it will be the best of all to keep, well the life will be short lived im sure. 2 way? 1.5 Way?
Did you manage to get that oil cooler setup at all? or Dry Sump? :laugh:
Oh you mentioned a surge tank setup i think :S Please inform us along the way on your descision here What size, you going 1 lift 2 feed to 1.8L or 3L surge setup? or bigger :)
Cams, The fundamental of flow, i say what the hell go the 272 ex/in 10.5 lift Its the way to the sky my friend.
Cheers
:) Adam
on a side note: i thought this thread was about noel's "goodbits" oh how wrong i was.
whats different betwwen either? only difference i see would be enlarging the oil galleries in the rb30 to spin it to 8k
are you the one building a 3 litre twin cam? or have i mistaken you for someone else?
by all means enlarge the oil galleries and rev the RB30 to 8k, i bet you'll get approximately 2,000rpm shy of that.
more mods are required to get the 3L bottom end to rev to than the 2.5L bottom end. there is a great deal of difference in approach and costs.
harmonics anyone?
Cheers
:) Adam
One thing at a time Adam, Rome wasnt built in a day. But just for uou heres my wish list.
clutch will be a berry item. Gearbox will simply be stock with new bearings and cryod gear set to begin with. (we'll fight that tiger as it arises)
Brake setup will definitely be 33 gtr brembo setup. Helped andy do his and yeah. sweet brakes.
Suspension is a headache. Most coilover setups I have seen turn a nice riding car into a cart. Hate it. If sombody made an adjustable setup that started at factory settings and then upped the stiffness and rebound etc from there they would own it. Comfy near stock settings for day to day driving and some adjustability for track work would be nice.
Diff will be simply a 1.5 lsd
Oil cooler is on the way as we speak.
Sump is being sent next week for baffling, gates etc.
Cams wont be quite that radical mate. Looking for something with relatively high lift and short duration on the exhaust side and similar but with slightly more duration on the inlet.
q45 tb is on the way
q45 afm is already here.
Need a custom himmount exhaust manifold ( need probably not but want)
Splitfires this week
Pro comp power fc with hand controller. launch control and laptop port will be here in about 2 weeks time.
And the myriad of little things that arise when you undertake this type of build up. Adjusto cam gears, silicone and braided lines and hoses etc etc.
It wont happen overnight. I am a working man like most and can only do it as I can afford it.
Next step in the chain is to get the head assembled with the stiffer springs and new cams.
once the sump gets back I will fit a N1 oil pump and we will reassemble the long engine. cr is currently 8.7:1 but I may up that slightly to give a bit more squirt down low. (tuner can take care of timing to suit)
And I will have fuzzy dice for the mirror and a nodding dog for the rear parcel shelf. Thats about it Adam.
Noel man...I am running street style n1 Apexi's...and they are sweet. They are not rough at all...very nice ride i will be gettin them rebuilt if they start to fail thats how much i like em. If you want to see then i will take you for a ride.
Peace
Peace
Would love to Obi. To date i havnt seen a set i liked but i hadnt heard of these. We will definitely hook up at your convenience for a try out bloke. thanx a whole heap. ;)
What makes you think the A-LSD wont be strong enough? It is the same as a Vspec GTR it should handle anything Noel throws at it! Unless he turns really insane
Yeah they do that in a straight line...it aint broken its just how they work. Keeps you straight that way...They dont like full on burn outs but when you acutally lauch you will see it still leaves two stripes..and you wont fishtail like with other LSDs
BUT he wants to run some slicks on the sucka sometime so it'd be fairly dangerous at the strip if only 1 side is warm and the other isnt, hello concrete wall :)
Thats what you get when you use somthing designed for the pure science of the track as a caveman driving in a straight line mobile :happy:
shanef has a dry sump...but noel ...i like the way he is going response will still be awesome...maybe you might even think about putting twins on it? get some serious response from small ball bearings.
A properly sized single shouldnt have any less response than twins
Times 2. I thought about twins briefly. Too many hassles in other areas tho.
Heres a question for those in the know. Is the power fc series specific. Meaning, will a pfc for a 33 gtst work on a series 1 and 2.
Same for S1 and S2 Noel
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
