  • Replies 75
Ive just installed the GTR pump. Quite noisy but then again I only have about 10L of fuel in the tank. Can hear it wirring away. Might take it out one day and put some rubber around the pump in between the hose clamp.
I was worried the pump might be on the way out but it seems that a few people seem to find them noisy.
I tried to keep it from resting on the tank but it was pretty tight in the R33gtst. Its a sedan so I'm not sure if the tank is a different shape.
Anybody pulled them out to put rubber in there and found it reduces the noise?
Thanks
Thanks
I did this to my sedan about 3/4 weeks ago, the pump is bit noiser than the standard one. I did a search about it on here and the noise is common. I got the stanley knife out and clipped a few bits outta the rubber mount, and am still getting the buzzing. I personally have no dramas with it at all, its not that big a deal.
Be interested to know if the tank is different between the sedan and the coupe. Any body have any clues?
Let's see if I can either remove the confusion or add to it.
1. I have never had a GTR pump make more noise then fail. Noise and failure are unrelated based on my experience. If the pump is noisy, then 99.9% you haven't installed it correctly. ie; it is touching the tank wall and/or floor.
2. Cable ties are fuel resistent, I use them to hold the filter (sock) in the right place. Don't need or use the circlip.
3. The device on the top of the pump is the anti syphon valve, it stops the fuel running back from the fuel rail and making the car slow to start. The fuel rail is higher than the tank, so fuel runs back into the tank when the pump isn't pumping. The anti syphon valve means fuel is always in the lines, no waiting for the fuel pump to pump fuel all the way up to the rail before the engine will start.
4. Talking about installing the fuel pump in an R33 takes longer than actually doing it. R32's fuel pumps are a piece of cake compared to R33's because of the accessability of the tank and its shape.
5. The pump earths via the terminals on the top, it doesn't need earthing via the body to work (pump). The body earthing is a back up (safety) link, in case the earth wire breaks and a spark jumps from the (unearthed) pump body to the bracket. I have only seen this on R34's where Nissan added insulation to dampen the noise. The larger pumps in R32's, R33's and Z32's also had insulation, but no earthing. So it is obviously a later thought by Nissan. Personally I don't worry about it.
6. The dual voltage for high and low fuel flow is controlled by the fuel pump relays, the low flow circuit has a resister in it to lower the voltage. The high flow circuit runs direct (no resister). The ECU controls the relays.
7. If you install an aftermarket pump incorrectly (ie; touching the tank floor or walls) they will make just as much noise as a GTR pump that is incorrectly installed. They will also not pick up the low fuel if you install them incorrectly as well.
8. Make sure you install the filter (sock) EXACTLY as it was with the standard pump. So pay attention to the orientation when you remove the standard pump. Don't pull it apart and then try and guess/remember where everything goes.
9. Walbro fuel pumps are NOT a good idea on turbocharged engines, I would never use one on a Skyline.
10. All the effort is worth it in the end, we have an R33GTR running 304 rwkw on the standard pump with a separate (dedicated) relay. They have plenty of capacity, if you install them correctly.
:) cheers :yes:
Thanks SK.
I might have to put the rubber in then to quieten it down and watch where it's resting. If cable ties are ok then maybe I should take of the S/steel hose clamp and use those to attach it to the cradle. Atleast then there isn't the bulbous piece of the clamp getting in the way.
I did take an approximate view of where the orientation of the sock is. Hopefully I got it close enough.
When you say you cable tied it did you just tighten up the cable tie on the plastic of the part of the sock that mates to the pump? Did this generate enough pressure to stop it from spinning around?
Thanks SK!
Edited by benl1981
Thanks SK.
Thanks SK!
I cables tied the filter (sock) mounting to the hose clamp.
I use 2 hose clamps to hold the pump to the bracket, get the orientation right and they clear OK.
:rofl: cheers :)
Ok thanks.
So would it look something like this (see below). You just use one cable tie around the lug feature (of mounting of the old sock) that usually locates to the post then tie that to the hose clamp?
And Sk do you usually use some rubber?
Do you have any piccies of your pump assembly/setup?
Edited by benl1981
That's exactly what I did, and that's what I said above. 2 hose clamps. spot where you've got it in your picture.
They're $1.99 man
How tight did you do up the hose clamps? I do them up really tight.
Tomei/Nismo pump sounds exactly the same (if I could tell you me info, it would explain why too).
Feel free to compare it to my car (installed properly).
edited: hose clamps not cable ties :D
Edited by MANWHORE
:D cheers :)
Awesome help there mate. Even though i have already done, it does interest me a lot to jnow about how and what otheres know and hae encountered.
And Ben1981, my cradle was re-installed the exact same way as stock. The sock is on the same angle, there is no movement where i cable tied it all up, i wouldn't stress it eh.
:D cheers :)
Nice points there gary. I agree 100% with what you said. Install is everything. IMO, the rubber on the later pumps is a waste of time and money. when I install the pumps, I just pop the rubber out. last install was done on a car with very very limited space. the rubber doesn't make any difference if it's clamped on properly. I find the rubber makes it more likely to buzz on the tank if it's mounted at the side (like the r33). rubber touching the tank still buzzes just lke metal touching the tank.
Installing it into the r33 was actually pretty simple for us (no dramas at all)
Its a buzzing noise. Very loud. The clamp is very tight. It possibly might be resting on something...Ill have to check. Its a very tight fit. I find it hard to believe that you can get it so it isn't touching somewhere. There must be a very small gap in some areas (around 2-5mm). THe rubber shoud still stop some of the vibration/noise transmission. SK did you use rubber?
Did you use the cable tie as shown in my pic SK?
I bought heaps of hose clamps so I'm not being cheap Chris :D
It's definately not liveable the way it is. I'll have another go on the weekend when I'm down to ~10 litres fuel again.
Pain of a job though.
Edited by benl1981
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers)
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
