"I Dont think the market is down at all. More a natural depreciation thing as the cars get older the same as any other vehicle."
If they are going down in price due to depraciaion then the market is technically down. Because they have hit that certain bracket of age where shit is getting old enough to need replacing on them than that is meaning the market is down. Put it this way - toyota sprinters were selling for a lot less a few years back but due to intial d, drifting, etc etc etc the market has gone up on them. Depreciation doesnt even really affect them near as much as skylines. S its not really like any other vehicle.
Same could happen to skylines once they become a lot more rare and hard to find a un raped version. Wait....it is hard to find an unraped version.
  • Replies 40
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
