Guest DFLASH
how bout all those trucks, old vans and bombs with black puffin smoke comin out of their exhaust... you don't see cops defecting them... and how bout cars with busted brake, tail or head lights... see heaps of those, in fact I nearly merged into a stupid Lancer on my way home just then cause his front lights were busted, only one parker was working... lucky i triple checked my blind spot and noticed a dark shadow... I was about to yell at him as I passed but his windows were closed.
TRUE TRUE TRUE!!!
i got caught doing a burn out in kings cross a while back, got my ticket and also got defected for being to low, i had standard suspension, a week later i took it in to the rta at botany, because they mayed me do a full inspection, i drove into the rta paid the fee, went to the pits section they took my defect notice and my paid receipt, waited 10mins they called me around, drove in they checked my ride height, the inspector then told me to pop the bonnet, got some numbers down from the plates and signed the papers and told me to go have a nice day everything is fine, a week or two later i get pulled over for nothing and get defected again, this time for a whole lot of things, to low, exhaust to loud, gauges, air filter, bov, front bumper loose, and gives me two days to get an inspection otherwise i cant drive, i go back to botany rta they say its fine u can go, have a nice day,
ps. i took the gauges out
P's attract attention.... And imports attract even more..... Its insane, and in my area, southwest and sutherland shire, its getting worse by the month.... If gets any worse over the next few years, I'm moving to Tasmania.... I don't see the cops getting any better... I'v removed my P Plates for the last 3 months, and haven't had a single "random" breath test, or as much as a glimps from a cop....but when i had the P's on, I had 12 "random" breath tests in 6 months..... Not to mention the "you were speeding" attempts from an Ashfield Highway Patrol Officer Number 9, who told me I was doing 130 on the M5... he pulled me over doing 100, legally, and told me i was doing 130, to my repeat answer, "I was doing 100 from King Georges Road", until he gave up, and followed me home... all the way from Belmore road to Menai... I even did a Maccas drive thru at Padstow.... Persistant bastard, still got nothing...
By the way, if anyone ever gets the chance to, tell a cop he has 2 tail lights out at the traffic lights..... They like to tell you that THEY enforce the rules, and you don't..... Commondore cop cars ALWAYS have a light out....
S of S
funny u say that, my friend used to work at Holden in Artarmon, they services a lot of cop cars, and they say that every time a cop car leaves the service centre they leave them with a defect because if the cop car has a defect they carn't book you. eg. my friend over took a cop doing 80 in a 60 zone and when he got pulled over he said "officer u have a head light out" and the oficer knew what he meant and said slow down and let him off.... i wouldn't recomend testing this tho, my friend has since lost his license
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
