Wheels 16 or 17 x 8's to suit R32 GTS-T (4dr)
Okay its time - I was pipped by 700th of a second in the hillclimb and my opponent had R tyres. My standard tyres have to go (is my competitive streak showing?? Maybe I should push those horns back in, they're starting to show).
I'm currently running stock standard 16x6.5's. I've heard that pre 94 GTR wheels will fit (thanks Jayce). Does anyone have anything that will do the job for me?
I also have for sale 17x9 Sparko wheels and Falken tyres to suit GTR (they fitted the front but were too big for the rear, wrong offset :( ) I'll be putting more about these in the For Sale section with photos soon.
If there are any enthusiasts out there that are interested in helping me get this car set up right (that won't charge me an arm and a leg... although, I am prepared to give up toes and fingers) I'd really appreciate the help.
Please PM me with any thoughts, ideas and hopefully faster wheels :woot:
Thanks
Michele
Edited by LadyBytes
https://www.sau.com.au/forums/topic/167689-help-wanted-wheels-16-or-17-x-8s/
if your interested i have some R33 GTR wheels for sale.
17x9 +30 dont know if the offset is right for a 4 door but i have seen one around with them before.
PM's sent
I've been working long hours and going through the posts now, thanks to all who have responded, your help is appreciated.
Sticky - I have a set of 17x9's and they're too big for the back because of the offset, I'm looking for 8's if I can.
Nisswreck - I'll give you a call, I hope you work Saturdays :rolleyes:
Cheers
Michele
Michelle,
This guy on NS.COM has 17*8 sparco rims...
I remembered you when I saw it there.
Anyways check it out if you're interested.
http://www.nissansilvia.com/forums/index.p...howtopic=234023
Cheers,
Beau
Edited by insanity
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
