  • Replies 49
hey aaron. i'll be there with bells on. I'll drop in tomorrow avo when i pick up my car and put a payment down. Will give me a deadline to get my bloody fueling issues sorted.. otherwise matts Lexus Toyota might out dyno me :thumbsup:
p.s. if i bought a set of spitfires off you tomorrow would you be able to bang them in for me ?
Sure mate
Ive jsut finished running a car in literally 5 minutes ago and its nearly 4:30 am
So i wont be at the shop for too long.
Ofcourse you do *patpat*
I will be there zarron. I won't do much but i'll lend you my pink hat :D
yay :sorcerer:
