MITSUBISHI GSR-EVO CLUB IN CONJUNCTION WITH COMPLETE AUDIO PRESENT
2003 SPL SHOOTOUT
Date: Sat May 31st
At Complete Audio Goodwood Rd Wayville
12pm please be there on time to enter
COST ;
members gsr-evo and psi $2.00
non members $10.00
> entry forms available on the website www.gsr-evo-club.net or on the day.
See you there competing for trophies and prizes or just come check it out enjoy the sausage sizzle and say HI! Let's see who has the subs to prove themselves here.....
That is a bloody shocking date for a car event in Adelaide, and I'm fairly sure that the GSR-Evo club were even advertising our drag day on the NissanSilvia.com website for us! Never mind ....
Nightcrawler.... you are correct. But just letting those who aren't going to the drag knows that there are other things on that's all. Considering the drag is a close door event and no spectators are allowed. I will be at the drags, since I don't have much of a stereo system.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
