Due to other commitments, I have been forced to put my project on hold, and have the following kit up for grabs:
HKS 2530 Turbo, in perfect condition, no shaft play at all! been checked by Shaun @ Boostworx
HKS intake pipe to suit.
HKS Low Mount cast manifold with external wastegate, awesome design! Brand new.
HKS Wastegate
HKS Stainless Steel Dump Pipe, ( might need to be modified to suit your application)
Stainless Steel Oil lines
Water lines
Bolts
Nuts
Gaskets
I want to sell the whole as a kit.
This setup is good for an easy 240kw on an RB20 with supporting mods. Good luck!
I am asking $3200 ono now $3000
SEE BELOW FOR CONDITIONS
Cheers
Ric
Edited by Richo
https://www.sau.com.au/forums/topic/167862-hks-2530-turbo-kit/
HKS Wastegate
Water lines
Bolts
Nuts
Gaskets
thats a 99% bolt up kit mate the price seems fairly resonable to me
you'll prob have to drop it over time if it doesnt go fast but i dont think you will have a problem
goodluck with sale mate !
thanks mate, i think it is a reasonable price, but I am open to close offers, no low-ballers though.
Btw how the hell do I put pictures on threads now? they took out the option to put a file from your computer :thumbsup:
Cheers
Ric
Yes mate, ran out of funds :P if it doesnt sell by the time i get some more money together then I would definately put everything on! we'll see.
Richo mate your selling Leons old turbs already??? Spewing you couldn't keep her, was wondering how you were going with it!!!
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
