  • Replies 120
Both ossie and JBaby have disapeared. I bet they are down the local mcdonalds already!!!
Should head down there and have a look whats going on :no:
or
:domokun:
LOL
Hope that didnt offend anyone. Not intended to. Just having some fun
tears tears i thought cry hahah jokes there bosses prob starting yelling at them for not doing there work haha i still think we should smash ronald just to vent my rage because weights at the gym are heavy and tyres arent cheap :domokun:
i think we just got husseled or we got moved by a member or something ahahahaha lets get it back to a cruise then move it back then change again
ossie do u really have plans i think hes waiting :laughing-smiley-014:
hahaha dan take us there in the skyline haha see now were not getting any one look at the post except dan hi dan :domokun: hi Dan cool but sorry not as cool as R dirty 3 hes goig to show me his pink stuff hehe :laughing-smiley-014:
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
