Saw on the news today that the cops are sick of bikies and shootings etc (another stereotype) so they are having a massive crackdown, and even admitted that they will be purposefully harrassing them, looks like we "hoons" are in the clear for a few weeks
https://www.sau.com.au/forums/topic/168155-massive-bikie-harrassment/
Why wouldn't they. Start with some disaffected youth, add in the dream of being untouchable, stir with a healthy dose of drugs, then bake in an oven where those drugs are illegal and thus provide profits without having to work much and you have baked a tasty bikie cake.
you left out all the guns/firearms/weapons.....!!!
give that recipe to Jess... she could make it better :(
and yeah, cops dont go after bikie gangs... thats stupid... would you if you were a cop?
they are worse out of the cities anyway... way worse... basically no law there...
i once got cut off by a bikie gang... i tried to boot it up the outside and they just took up the entire road (3 lanes, there were 4 bikes, gang insignia on the jackets) f**ken glad i didnt hit them... decided to let them do whatever the f**k they wanted after that... probably the same way the popo think...
If you wanna piss off a bike rider (dont do it to bikies tho) when you pull up at a set of lights (on a 2 lane road) sit as close to the center line as you can so they can't fit between you and the car beside you. Man that gets them fuming!
Bikie gangs very much still exist.
Most of the time you don't even know the "chapter" house is in your area, until you actually take a lot of notice.
They're usually in back areas or semi-industrial areas.
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
