Hi all,
I've just been looking at the Wakefield Park website, and their holding the NSW Drifting Championships there on the 3rd of June. Is anyone going along?
And on a different note, I need to get my ceff engineered in NSW, and I've been recommended to John Wilson of AKZ engineering here in Queanbeyan. Anyone had any dealings with the guy? The one person I know who's dealt with him said he was pretty god, pretty thorough.
Cheers,
Mick
http://www.driftaustralia.com.au/news.asp?newsitem=158
Backed by Toyo, with $1500 for 1st prize. They also have a encouragement award from HSD/Otomoto of $500.
I might enter, if not I might be pit crew for someone else.
I heard John Wilson is not very consistent, but I've never personally dealt with him.
Wilson is tops he engineered my 1600 and gave me heaps of advice on things.. Dickson dont like him tho not sure why but prob cause he engineers heaps of cars and doesnt charge thousands of dollars like the "other two".
John did all my engineering when I brought in a handful of 15 year old R32 GTR's. I can't comment on one off experiences however I found him knowledgable and well priced.
I would have to agree with TeeJay1600 about the Dickson inspectors not holding him in the highest regard. Perhaps because he is in a position where he can and has challenged their interpretation and enforcement of the ADR's.
Never say no to an offer of help >_< Hopefully nothing will go wrong but come and say hi at the very least.
not a prob well i'm on holidays the week leading up to this so yeah plenty of spare time on mine hands so if you can use an extra pair of hands for anything let me know it'd be good to see what sort of work goes into getting the car ready for a drift round i'm hoping to have a good go at it as soon as my car is back (when ever that will be) but with coilovers, button clutch. mech lsd and 260rwkw, i think i should have a car quite suited to it
Sounds like it'll be a beast. It'll be awesome when that gets to the track.
Honestly there's not much to do between now and the day. Now that my week permit is over I'll wind the preload on the front coils back down, probably should do a service. I got my tyres from Jax yesterday (hope 6 rears last me the day).
Might see if I can find out why it wasn't boosting past 0.9bar on the dyno the other day. That's about it. It's a bit of a budget car so there's not all that much to it.
Well it's official now:
Entry list:-
Darren Appleton - QLD
Eugene Arendsen - QLD
Catherine Coleiro - VIC
Glen Drysdale - NSW
Travis Dunstan - VIC
Chris Easton - NSW
Leighton Fine - SA
Scott Gibbs - NSW
Brad Green - NSW
Jason Greenwood - NSW
Ashley James - NSW
Josh James - NSW
Chris Jones - NSW
Chris Laverick - NSW
Mike Laverick - NSW
Andrew McGregor - NSW
James Mijoc - NSW
Marcus Newark - NSW
Sam Pass - ACT
Lee Pidwell - VIC
Christian Pickering - SA
Matt Porter - NSW
Ben Ryan - NSW
Azhar Sadien - NSW
Cameron Stubbs - NSW
Michael Truscott - VIC
Igor Tunjic - NSW
Jarich van Horek - NSW
Eiji Wakamatsu - NSW
Nathan Weissel - NSW
Dean Williams - NSW
Dion Yandle - NSW
Though they've got me down as coming from NSW. Are you there Stinkypoo (I don't know your name)?
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
