ive swapped over to the smaller 324mm brembo brakes as i need to fit smaller wheels on my car for track
u will need 18" rims for these brakes
343mm AP racing 4 pot brakes and 2 piece rotors
disks are in immaculate condition hardly any wear whatsoever
only things theyll need is maybe a new coat of shiny redon the caliper to look brand new :stupid:
asking 2k PRICE DROP 1800
previous buyer fell thru a month or so ago and after constant msgs etc and no reply thyre back up for sale
some good pics monday but this is all i have atm
Edited by 747.GTR
Hi mate,
This could work out well for three of us. you, 32corey and me.
I'm interested in your rotors. if 32corey takes calipers i"ll take rotors off your hands, obviously at a cost.
Do the rotors have 10 or 12 bolts holding the disk on to the hats?
PM me if you are interested in seperating!!!!!
Hi mate,
Hi mate,
  • 4 weeks later...
  • 1 month later...
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
