Hey forum just wanted to know if turbo size affects exhaust note. Have a turbo back system on my car and the exhaust note didn't really change got just a little deeper but basically remained the same. Its 3" front/dump and decat pipe and from the decat pipe to muffler 3.5" apexi n1 cat back then a 4.5 inch cannon at the back. I was thinking this would be extremely loud but its just as quiet as the stock muffler just a little bit deeper. Its all tied in to the stock turbo tho thats why I asked if turbo size affects exhaust note. All and any advice is greatly appreciated.
https://www.sau.com.au/forums/topic/168450-exhaust-note/
The Resonator on your Apexi N1 cat-back will have an affect on the noise level of your exhaust, I'm not sure where you are if its legal or not but if you want the car to be loud then you'll need a split dump with a screamer pipe outlet and customise the cat-back so it has no resonators.
If your Apexi N1 exhaust is quiet as stock but deeper sounding then I'd leave it, most people try to find that and never acheive it.
https://www.sau.com.au/forums/topic/168450-exhaust-note/#findComment-3113478
No I love how it sounds just was wondering as I thought it would be much louder. I will soon have another turbo to install and was just thinking if the exhaust note would follow the same pattern. I have a split front/dump with a screamer and when the wastegate opens, "DAMN!!!!" but during normal driving and acceleration the note is excellent just a little bit deeper than stock will try to get a sound clip for you.
Ohh I live in the Bahamas by the way. :nyaanyaa:
https://www.sau.com.au/forums/topic/168450-exhaust-note/#findComment-3113620
Turbos in a way are a muffler aswell. N/A's of the same motor are heaps louder
^ Yup. Anything that stands in the way of the gas flow (and the sound waves that move through it) will dampen the sound. A I6 M3 with a big zhaust is ear splitting.
Replace the second muffler with a resonator, and keep the $ for the fines
https://www.sau.com.au/forums/topic/168450-exhaust-note/#findComment-3122327
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
