I installed a new turbo back exhaust on my R33 GTST and I found that when I fang it right up to 7000 RPM then back off, as soon as it backs off to lower revs, I hear this slight pop off sound (almost like a slight fart) that the car gives off... just wondering if its all ok.
I run stock BOV and otherwise the car is stock. Its also auto.
https://www.sau.com.au/forums/topic/168579-zorst-question/
So the fuel runs through the turbine and explodes after? :P Me thinks not...
he means its unburnt fuel cos your car is running a little rich at that high rpm, obviously would run a little rich cos its not designed from factory to be kaned.. but its normal... not sure how it is when you have it tuned
https://www.sau.com.au/forums/topic/168579-zorst-question/#findComment-3118466
hey what exhaust did you get (custom or brand name) could you possibly post up a sound clip? Also what size is the piping.
I got the JJR Hyperflow Turbo Back Exhaust, stainless 3 into 3.5 inch System from Just Jap.
I can try and record a sound clip later on.
Its loud between 2000-3000 RPM but when cruising on cruise control at 100 KM/h its virtually silent... my car is auto too.
https://www.sau.com.au/forums/topic/168579-zorst-question/#findComment-3118645
So the fuel runs through the turbine and explodes after? :laugh: Me thinks not...
i didnt refer to fuel running through the turbine!
reffering to the exhaust.... its getting pushed out when on the accel. then when changing gears or off the accel it pops ( like back pressure). well mine does anyway... im sure its very common.
Edited by jake33
https://www.sau.com.au/forums/topic/168579-zorst-question/#findComment-3118816
Ah cheers, so theres no real drone when cruising at 100km, would it be possible to record from inside the car the next time your cruising at 100km if you get a chance. Majority of the driving i do i highway kms so really dont want droning :laugh:
https://www.sau.com.au/forums/topic/168579-zorst-question/#findComment-3118830
Ill try my best, give me some time.
But yeah the most drone you get is when you rev it between 2000 and 3000 rpm. When crusing on the freeway its virtually silent, basically like the stock exhaust... this was my worry before I got the exhaust as I didnt want it to drone when cruising at 100 KM/h... no problem at all...
And you get used to the drone after a while at slow speeds, infact Im enjoying it now.. and my GF doesnt mind it at all, says it sounds "tough."
https://www.sau.com.au/forums/topic/168579-zorst-question/#findComment-3118888
    • You can’t see much on the other side as the lcd is there I don’t think it’s the same as the m33 beside it as the markings on top is not the same was hoping someone had a good quality photo or if they just happened to have the unit in hand, quickly take the cover off and take a photo to clearly show the marking on top to identify the diode   the unit is currently with an electronics repair shop so I can’t take another photo at the moment hopefully they are smart enough to know if it’s a zener diode or not
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
