I really don't understand you people.
You's sit and whinge behind your computer screen that there's not enough meetings/gatherings excetra, but I've got two events on the go at the moment, and only three people have responded to both.
If you's really want to get this thing happening, get off your arses and attend some meetings.
NOthing's going to be handed to you on a silver platter.
I've spent a lot of time organising the drive in movies and I've also spent alot of my own personal time liaising with the owners of the carpark trying to get us a place to meet.
If no one turns up to these events that I'm organising, I'm really going to give up and not bother with this anymore.
https://www.sau.com.au/forums/topic/16874-confused/
I can only agree with Slip. Once the club is up and running we may be able to get more interest, commitment and team work from people. The Sprint days are a prime example. Many clubs have championships for events (which can include all kinds of things, like sprints, drags, show and shine, cruise, and general attendance). So far the count at any event mentioned in the events forum here has been fairly low to non-existant. I know its early days still, and I know people have very good reasons, but I tend to think until the club becomes official and there is a structure things won't change much.
That aside, stay positive about this. We have a good variety of events happening (official or not) and it should cater for all types and interests in this club. I'd love to see more people at the events, but it's up to each individual to get involved. The only thing I can say is don't be backward in coming forward. As NismoGirl has said, get off your butts and come along. There is more enjoyment to owning a performance car than you may imagine.
https://www.sau.com.au/forums/topic/16874-confused/#findComment-348465
Erin,
Although we have had our disagreements in the past, I can honestly say that your efforts are always noted and appreciated by most people who post in the qld section.
Dont get disheartened and keep up the good work...
Smooth.
PS- i see now there are more than 3 posts in those threads so its all good. :)
https://www.sau.com.au/forums/topic/16874-confused/#findComment-350286
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
