Hey guys, i have to replace my lifters, I just had a quote for genuine nissan lifters for $3400 and thats not including the labour!!!! I cant get my head around this, it seems very extreme and is worth more than a stock rb25det. Apparently there is no aftermarket lifters for this motor so genuine is the only way to go. The thing is ive had 2 mechanics look at it and they say its only 1 lifter making the noise but they cant figure out which one it is!! Has anyone had this experience before?
https://www.sau.com.au/forums/topic/168767-lifters-for-rb25det/
That seems a bit ridiculous.
These are solid lifters for rb25 for 48000yen - which is about $566AU. Look down the list and you'll find em.
http://hioctaneracing.com.au/jshop/advance...or+nissan+or+u:
Dunno a price on hydraulic ones though. That's all i could find so far.
Edited by KeyMakeR33
Yeah i know what u mean mate but my mechanic is a family friend. but i have been stung before by dodgey mechanics. I called nissan to confirm that and they quoted me $5.36 extra per lifter compared to the price my mechanic got for me.
Yeah sounds a little crazy to me.
Watch out for mechanics that because they cant work out what the problem is will just start replacing stuff untill the car is ok again. They dont care because they make money on the parts and labor.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
