Most of the skylines that have them would be from the compliancer more than likely - most 34's are released in Japan with xenons and they get changed here for compliance - then some people put them back on :spank: I would guess the assembly of these would NOT fit your car.
Check here for local kits: Xenall that would probably better suit your car - and ADR's!
they also have:
Melbourne Sales and onsite fitting!
GiJOr33: have you tried calling them to check or are you just basing that info on their website? Personally I would give them a call, Xenall and Motorware :)
Or perhaps you could try and find a set from the series III r33 GTR - I think they had xenons which should fit your car - theoretically!
My point though is that the price is NOT comparable either :D
I have the real thing but I wouldnt have paid $1,000+
I have seem plenty of cars on the street that dont have xenon but their headlights look much nicer with white lamps - yellow is just a bit 80's to me...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
