Hey Everyone,
I think the fuel indicator maybe stuffed.
I purchased a R34 GTT about a week and half ago, had put in fuel 2-3 times since I have had the car (however had not yet filled tank), and had no problems.
However I filled the tank for the first time yesterday, have just noticed that the the needle has not really moved, maybe very slightly , however I have done around 80km since I filled her up.
Also when I turn off the car the needle stays put (at full basically).
Is there any easy fix for this do you think?
If it is stuffed, do you think it will still warn me when I am getting close to empty?
I have no idea yet, how many Km's I can get out of a tank, so makes it a pain in the backside.
Anyway guys and girls , thank you in advance for any assistance.
Regards,
Cargle.
Edited by cargle
https://www.sau.com.au/forums/topic/168928-help-fuel-indication/
Yeah, try ask in the skyline section, but for what it's worth,
The cefiro fuel gauge stays still when you turn the car off (even if you pull the cluster out it stays put).
And 80km's isn't too much from a full tank, you should be getting at least 400km to a tank, I would expect more from a newer car (R34) and depending on level of mods, maybe even 500kms.
Do another 100kms and see what the fuel gauge is doing then.
Otherwise it's not very hard to remove the fuel gauge/pump cradle.
My Cefiro fuel guage needle has recently developed a quirk of its own.... I fill the car up, the needle says half full. I drive 200 km, still half full. Drive 300 km and the needle starts to move down rapidly. 320km the warning light comes on.....
but I do have a 1jz, and I don't drive it too carefully so I know that I'm getting terrible economy... but the fuel level sender has got to somehow be stuffed.....
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
