bought this a few months back for project car. unfortunately need the money for other things at the moment.
genuine garret gt2876r biggest of the t28's
ball bearing
flows the same amounts of air at 9psi as the S15 T28 flows at 16psi
garret has rated the turbo for 280-480 Horsepower and recommended for 1.8L - 3.0L Displacement
has approx 2000k's on it so virtually brand new
.86 rear housing
sad to sell but need cash
$1000
let me know if your interested
located in brisbane
pick up preffered will post at buyers expense
Edited by FYN_32
https://www.sau.com.au/forums/topic/169102-fs-garret-gt2876r/
will this be alrite for an rb20 or abit laggy do u think..?
chris from mercury motorsprts told me it would have 1 bar of boost by about 4000rpm. was going to put it on my rb20 but need the cash.
it should be good on an rb20 because it produces more exh gasses than a sr20 and these are mainly an sr20 turbo..
i've got the same one on my car and so does deanr31.. this turbo is the sheitz! (very agressive)
free bump
so this wont bolt on to a stock rb20 t3 exhaust manifold then?
Would be interested if it does.
Cheers.
you can get an adapter to make it fit or just get the flange on the manifold changed
  • 4 weeks later...
    • Mixing things up - installed some leather recaros to match the leather seat covered rear seats. Interior looks pretty schmick now except for some slight wear on the steering wheel which I will monitor and address if it becomes worse or actually noticeable!
    • Didnt realise RB's had more then 1 head.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
