94' R33 GTS-T (400kw) 5 Speed
15,000 kms since full rebuild ($7,500 Balanced Bottom End)
700hp Garrett Roller Bearing Turbo
TRUST Intercooler
GREDDY External Wastegate
APEXI Power-FC Engine Management and Commander Unit
GREDDY Profec-B Electronic Boost Controller
NISMO Motorsport/Jasma Exhaust
Turbosmart Type III Blow-off Valve
HKS Cams
Forged Pistons
Adjustable Cam Gears
Inlet Manifold Powerported
Aftermarket Injectors
GAB Adjustable Suspension
17" Stern Wheels
New Clutch
Rear Strut Brace
Polished Turbo and Intercooler Pipes
Polished Oil Catch Can
GTR/RS Yamamoto Body Kit
Recaro/Momo Interior
NISMO 320km Carbon Fibre/White Dash Cluster
Autometer Shift Lite Tacho and Boost Guage
$4000 Alpine Sound System
Viper Alarm with Remote Start
DIVOT Turbo Timer
Electric Sunroof
Tinted Windows
4 New Dunlop Le Mans Tyres
Receipts
All work professionally carried out
Plenty more potential
Excellent Condition
This car will not dissapoint!
Please PM me for PICS.
$39,500 Negotiable.
BIGPSI Plates Sold Separately - Will take offers
0422 953 695
https://www.sau.com.au/forums/topic/16916-400kw-r33/
  • 4 weeks later...
Guys i can personally guarantee that this car is PHAT and FAST. This thing is a beast. I'm a mod for the VIC club and have no reason to lie or deceive.
Leon if u need some pics i still have those ones on my webspace if u need em just holla.
Whoever buys this wont be dissapointed cause its an animal...
Good luck with the sale mate and i hope it goes to a good home.
PS. havent seen u on much lately we will have to catch up... maybe this saturday at the meet?
Cheers,
Ni
https://www.sau.com.au/forums/topic/16916-400kw-r33/#findComment-396702
  • 1 month later...
  • 3 weeks later...
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
