$30,000 ONO (special price for Skylines Australia Forum)
Contact Mike on 0438-779-885
* Japanese domestic market vehicle - not sold in Australia - rare!
* Fully serviceable by any Nissan dealer
* Privately imported by the current owner
* Top-of-the range prestige Skyline model
* Engine - 3.5L V6 (206kW, 353Nm, model VQ35DE from the Nissan 350Z)
* Continously Variable automatic transmission (CVT) with 8-speed tiptronic mode (with steering-mounted paddles)
* Metallic dark silver paintwork
* 51,000km
* Factory low profile mag wheels.
* Factory BOSE dash loading 6 CD sound system with sub-woofer with steering wheel mounted controls and tape.
* High Intensity Display (HID) Xenon headlights.
* Power front seats, tilt etc.
* Power mirrors - direction and folding
* Full service history
* Factory bodykit
* Power steering
* Power windows
* Tilt adjust steering
* Factory immobiliser
* Factory tinted windows
* Dual zone climate control air conditioning
* Air conditioning vents for rear passengers.
* ABS brakes
* Sports exhaust
* Vehicle "Dynamacy" Control (selectable)
* Dual air-bags
* Remote Central locking
* Factory Nissan security
* Rear wheel drive
* Leather steering wheel
* Leather gear knob
* Factory race pedals
* Factory skyline carpets
* Full Trip Computer
* Factory LCD screen for trip computer, with inbuilt television/DVD satellite navigation (tv and satnav require some conversion for Australia)
* No accident history
Edited by v35gt8
Hey, can't believe they make the same model in sedan as my coupe, it's kinda a wierd. It's like a beefed up nissan maxima isn't it? :)
oh well, good luck with the sale anyway.
Edited by LEXREX
You'd only make that mistake once. :-)
The party trick is simply holding the accelerator foot to the floor. The CVT will put the VQ35DE in the middle of the power band and keep it there, putting all the power to the *rear* wheels. Its funny watching their faces as they drop backwards each time they change gears :-)
  • 1 month later...
  • 2 months later...
  • 1 month later...
Hi Mate,
Sorry cash sale as I have already bought the replacement.
The V35 Skyline is a good luxury car for people who want/need a genuine 4 seater (5 legal), but still want good pick up of a 350z engine.
The smart gearbox means you can have it sporty or maximum economy. Also rear wheel drive unlike a Maxima.
Cheers,
- mike
Trade you for a BMW 740iL (7 Series) V8 Luxury car
Used to be Danish Ambassadors car....
Edited by v35gt8
  • 1 month later...
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
    • I saw your intro update, are you sure you've actually had a starter motor failure? You mention it could be the alarm causing it. I'm assuming you've got a no start issue, but what are the exact symptoms, as there could be a few reasons it has stopped wanting to start.
