I like Futsal as a sport, it suits my style, this here is a great goal, very good technical goal indeed, worth the watch even by people that hate the sport.
http://uk.youtube.com/watch?v=7qkFlKizUfc
Edited by Pauly33GTS-t
this isnt as good as weng weng but still nice
織戸VS谷口めちゃうま!!
we all need to move to japan
here is jap drift club daylight on main roads
http://www.youtube.com/watch?v=5TZLNymbZuw...ted&search=
Edited by Madaz
Cockosaurus here belongs to members from these boards. I haven't asked their permission but they put it on YouTube so ...
****WARNING may offend young viewers and insecure guys*****
http://www.youtube.com/results?search_quer...p;search=Search
