What a farkin idiot!!!!!
not 1, but all four!!!!!
:cheers:
wasnt the drivers fault wrong wheel nuts from a dealer i believe put nuts on they went tight no probs first bit of pressure nuts shredded of the studs as soon as 1 went weight tranfered to each corner forcing them all to break :s must b something to do with americans i reckon!
Edited by shy_s6
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
