Hi,
I have been offerd 82mm Custom CP pistons and cometic head gasket. Anyone ho has experience on boreing the cylinder from stock 78-82mm? Are the walls thick enough or DOES the kit require cylinder sleeves. Nobody has ever answered this question, and I am a little sceptic to bore 4mm over. Afraid the walls will be to thin to handle any boost.
This seller tells me its safe and no prob. to have 82m pistons fitted.
And are there any diffrence on the cylinder walls on the early and late RB20DET engines?
Thanks for any replys,
Thomas.H
www.edgeperformance.no
Edited by impultion
https://www.sau.com.au/forums/topic/169846-rb22det-safe-to-bore-4mm/
Thanks, Hi went with 83mm pistons. 5mm over. I will hear with him wht hi has done with the block.
check the rb24 thread think the guy already has pics of his bored out not sure how big he went though
http://www.skylinesaustralia.com/forums/in...20&start=20
Hi, are you sure?
This guy bored 5mm over. 83mm on his RB20 block
Murravis:
Hi Mate,
The block i have used is from a 93 r32 gts-t
The walls are still pretty thick, i got them checked when they did it and they said there fine, There is no need to sleeve the block, i was going too but the machine shop said there is no need too.
We took mine out 5mm and there fine, if tomie has made pistons to do the rb22 or rb24 conversion at a bore of 83mm they must be fine.
on another note is that your engine bay below?
Cheers
Cameron
boring out an engine and then not inserting sleeves = engine rebuild in the near future.
Well a guy i work with is an engine reconditioner by trade and he's done allot of boring in his life. He told me RB blocks are bullet proof when untouched, never seem to wear much at all (especially RB30 blocks). But once they are boared it's a very different story, much faster wear etc. using inserts will prevent this happening.
As most people will know Cast iron only has a hard outer skin (add to this nissan uses gas nitriding to harden the surface further) and the inside is very very soft. Generally the skin only has about <2mm of 'hard' surface. If you want to take of 5mm from the diamater that's a 2.5mm deep bore which is most likely the castings skin gone or very thin at best. Hence the reason people use inserts because they provide the skin again.
Machine shops will gladly do the work i'm sure but don't expect your block to last as long. personally id go for inserts especially on a bore that big.
PS: Incase i confised anyone. it's not the strength of the wall's that i'm talking about it's the hardness which will casue premature wearing of the block. You don't want that!
Edited by deant1
Hi,
Thanks for that information. Do you know of anyone ho has forged pistons and rods to the RB20DET in stock?
Thomas
    • It's not any meta data. They have scraped images from everywhere, and then use AI to compare your photo to other photos and work out where you are.
    • I just looked at my camera phone settings, apparently I have "not allowed" for location  Will that stop that app?
    • Can you not just turn it off on your phone if required? I remember a brief on this, well, I remember the brief, not what to actually do. LOL
    • Thanks for posting, your engine bay looks tops. I'm fairly sure you posted the wrong video though, I think you were supposed to upload the one from your "private test road" where it's banging off the limiter with the gate open?
    • This is something to be careful of. I did a bit of digging on the NM35, as I spend a lot of time on near brand new cars and CANBus related stuff, which uses the same "OBD2" plug for a fair chunk of making my life easy. The NM35, does NOT support OBD2. The data pin is actually on Pin3, which is a manufacturer specific pin, and requires Consult3 to connect to the NM35. Your low voltage, is either because the NM35 doesn't have 12V to the constant power pin on the J1962 (OBD2) connector, OR, it is attempting the standard comms, (CanBus, K Line, etc) and can't see any voltage on those pins. Some people have had success accessing SOME data from the vehicle on OBD2 specification, using a module that supports KPW. My assumption, like Duncan has stated, it will likely actually be JOBD, where there is some cross over with the OBD2 and JOBD standards. Note, lots of "OBD2" dongles, do NOT support KPW, which is what you need for a lot of Japanese vehicles of this era (And even up until recent years!), EG, Subaru, Suzuki, etc.    The end of this thread is probably worth a read, as some people did find a way to get a display up in the NM35 recently, looks like someone implemented all the stuff needed to make it work. (The right protocols).
