Has anyone heard of anyone using this new piggyback ecu?
I's suppose to be the new replacement for the Power FC, I Used to have the SAFC2 and SITC combo on my r33 Auto and was considering giving this ago as it seems like the most logical ecu to use especially considering i have an auto and don't want to jeopardise my shift quality.
Was looking into the Emanage Ultimate but after seeing this i'm not sure what i want to do. Have searched the internet and not found anyone who has tried it yet.
My Tuner said it would be the better way to go than using the emanage ultimate.
I sent Greenline an enquiry asking if it will be alright for my car haven't heard back yet, if they reply and say it will be alright i will order it and install it next week and let everone know how it goes. Any feedback would be much appreciated.
Here's a link If anyones interestedhttp://www.takakaira.com/asp/template.asp?...PQqMnNnikJlhoKj
Edited by wildr33gtst
https://www.sau.com.au/forums/topic/169949-apexis-new-piggyback-ecu/
its been out for a while, but so far nothing on it
its only supported on the wrx auto for some stupidhead reason
its an line loom splitter that you plug between your stock ecu and the device itself, much like an emanage or fcon
my advice, given no one knows anything about it or selling it, forget it, dont even bother. wait a few years.
i cant see it replacing the powerfc any time soon
That's really stupid if it's only designed for the WRX Auto, I find it weird that their isnt much information about it and not many people have seemed to use it. I will wait back from a reply from greenline to see what they have to say about it.
What's the APEXi SITC you have in your signature?
Is that an ignition controller?
Meaning you already have some fuel and ignition control?
And you're in an auto?
If it's auto, pretty sure SydneyKid does all his autos with emanage.
Great looking software comes with it.
There's a thread somewhere with heaps of Emanage Ultimate pics.
If it's manual, you have heaps of other choices.
    • Why are people so insistent on making dirty water?!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
