yeah, font ftl...
and you, ftl...
im gunn ahave to pretty up my car too now! i rewired the boot so it looks better (still temporary :bunny:) and i wired up the tweeters and mounted them properly... no more drift spec :)
i think im gunna buy some paint and pretty some stuff up while i can :P
thanks doof, i'm the only one allowed to have drift spec applications....
besides, my boot will be finished soon and be prettier than yours...
As for paint and prep etc...
Everything that i've painted in my engine first had a bath in degreaser
then it copped a wash in turps to clean and dry it all...
COVER
- removed the plaque
- sanded the cover
- applied 3 coats of primer
- applied 3 coats of anodized blue
- applied 2 coats of clear gloss
PLAQUE
- washed in degreaser
- washed with turps
- spayed with matt black PLEASE NOTE THE COLOUR OF THE PLAQUE - Its primer not paint!!!!
- applied a few coats of primer
- applied a few coats of clear gloss
PAINT
Primer: Dupli-Color Metalcast Metalic Ground Coat
(reflective base coating)
Paint: Dupli-Color Metalcast Anodized Blue Paint
- "dazzling anodized colour effect over Chrome/ Shiny Surfaces"
- "high gloss"
- "heat resistant"
- "durable"
Paint is pretty much only available from supercheap auto @ roughly $17/ tin
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
