Item:
18 inch Works Euroline Mags with Nitto tyres
Fronts are 18 x 9 with a + 5 offset. tyres are 225/40
Rears are 18 x 10 with a + 10 offset. tyres are 245/40
and also have multi stud pattern - see photos, suit 5x114 & 4x114
Sunsine Coast
Item Condition:
Good Condition - the clear coat is lifting on a couple and needs to be re-done. other than that, no gutter rash or anything else. tyres have about 60% tread left.
Reason for Selling:
wont fit my aristo - need something with more offset
Price and Payment Conditions:
$2500 or nearest offer - pick up only or buyer to organise freight.
Pictures:
Contact Details:
email me at [email protected] or phone 0412750418.
i also cannot see the pics... but i would like to see the pics...but i can't... cos they're not there..
No, they are not...but they are here -> http://www.skylinesaustralia.com/forums/in...=170290&hl=
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
