Well as some of you know I had problems with my car losing power then kicking back in all of a sudden. First we thought electrical, but the mechanis said no, then the fuel filter...but apparently not.
Complete auto here in Whyalla is where i took it. They serviced my car, changed alot of piping and some other random junk. Costing around 700. They rekon they fixed the problem with what they did.......but they didnt. Now the rekon it could be the knock sensors i think they said, anyways they said theres two of them in my car. And they want to charge 1grand EACH!!! Lucky for me it was dad who has been paying everything.
Anyways dad's taking it into adelaide this weekend so hopefully somewhere there can help with the problem. Is 2 grand too much? AM i getting ripped?
Thanx >_<
Edited by Whyallapunk
https://www.sau.com.au/forums/topic/170416-pricing/
i think you're being taken for a run. sounds like they have no idea what they're looking for and simply changing whatever they think needs to be replaced.
diagnose your problem at a reputable mechanic - do it first time, do it right.
https://www.sau.com.au/forums/topic/170416-pricing/#findComment-3147512
FAAARRRHHHKKKK
for that sort of money, take it to an RB specialist tuner
much cheaper :/
and um, i was under the impression Non-turbo's didnt have knock sensors???
https://www.sau.com.au/forums/topic/170416-pricing/#findComment-3148173
  • 4 weeks later...
Thanx :cheers:
Howdy, this was a while ago but incase you check back here, where did you end up taking it in adelaide and how did it go? I'm in adelaide looking for somewhere to go for an N/A R33 service and some brake pads/gearbox work.. but all I have at the moment is a few places I know to avoid, nowhere recommended.
Seems either you go to a regular garage who is cheap but has no idea about skylines and cocks it up, or you go to a specialist garage who charges like you've got bottomless pockets and doesn't necessarily do the job any better unless you happen to know them.
There is a genuine nissan garage near my place but they quoted nearly $500 just to replace the front & rear brake pads. :D
With genuine nissan pads no doubt, i'm more keen on something aftermarket thats decent and reliable and costs alot less.
Any suggestions? must be some SA ppl here with some idea's..
Cheers
https://www.sau.com.au/forums/topic/170416-pricing/#findComment-3192920
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG is has not responded to my emails so far after purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
